Not all traffic on a segment is captured when using the LPA through an Automation Server
  • Not all traffic on a segment is captured when using the LPA through an Automation Server
  • Benji
    Benji
  • CraigEl
    CraigEl
‎2018-09-11 08:45 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:55 PM
When using the LPA through an Automation Server (AS) as described in Using Loytec LPA with SmartStruxure AS, only traffic to and from the AS is captured.
LPA
Automation Server
Due to a hardware limitation in the AS, it's not possible to capture all traffic on the segment
Connect the LPA to the segment using a NIC-USB100 or similar
  • 18069
