Not able to get Service pin from LON devices connected with Loytec NIC from ES
  • Not able to get Service pin from LON devices connected with Loytec NIC from ES
  • Cody_Failinger
    Cody_Failinger
  • sesa150555
    sesa150555
‎2018-09-06 03:34 PM
LonPort is discovered and shows as online but no Service Pin is received
  • StruxureWare Building Operation ES 1.1
  • LConfig
Since StruxureWare Building Operation ES is running as a service, the legacy driver also has to be.
  1. Open LConfig
  2. Click advanced
  3. Change Legacy Driver to run as service
  • 7522
