Monitor the online status of a base unit's associated I/O modules
  • Monitor the online status of a base unit's associated I/O modules
  • Cody_Failinger
    Cody_Failinger
  • Anonymous user
‎2018-09-07 04:30 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-30 10:49 AM
TAC Vista
  • Menta
  • Xenta programmables
  • Xenta 280, 281, 282, 283, 300, 301, 302, 401, 401:B
  • Xenta I/O Modules
Alert the end user to communication failures between a Xenta programmable base unit and its associated I/O modules.
  1. Add a DI block to the Menta program.
  2. Name the DI point
  3. Click the bind button and choose online device.
  4. Within the device address box, enter the I/O module number.
    • For module 1, type 1.
    • For module 2, type 2, etc.
    • Also, attached is a Menta macro that contains code for 10 modules. If there are less than 10 modules, remove the unnecessary points / alarms.
Note: Any I/O module defined in the Device Specification that has no hardware inputs or outputs assigned to it in the Menta application will always report an offline status.
ERRORS_IO.zip
  • 3292
This is a heading
