Manually Consolidating License Files
  • Manually Consolidating License Files
  • Cody_Failinger
    Cody_Failinger
  • Sacco
    Sacco
‎2018-09-10 03:23 AM
When using multiple .lic files, Vista Licensing Server can  have issues reading all the files. If the license features were not purchased on the same Entitlement, manually consolidating the licenses into one file will be necessary.
TAC Vista
  • Licensing
  • FlexLM
  • Vista
Multiple licenses not read which results in purchased features not unlocking.
  1. Open the .lic files in Notepad, Wordpad or text editor of your choice.
  2. Verify that each license to be consolidated are entitled to the same MAC address or Dongle.  Line 2 of the files should all have matching "Server This_host xxxxxxxxxxxx"
  3. Chose one of the files to become the "Master"
  4. Copy and paste the "INCREMENT" contents of the files at the end of the "Master"
The final result will be a file with one "Header" and listing all of the features below.
Tags (3)
  • 6275
  • combine
  • merge
