MFC errors on Continuum startup after moving a database to another PC
  • MFC errors on Continuum startup after moving a database to another PC
  • Alan_Wood
    Alan_Wood
‎2018-09-06 01:24 PM
MFC errors or Continuum crashes when trying to start after moving a database to another PC
Andover Continuum
  • Continuum
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
The startup attempts to resolve the Workstation instance in the database and if it can't you will receive MFC errors or Continuum will crash.
  1. Ensure that the sp_changedbowner 'andover97' query was run against the database on the new PC.
  2. Perform a Workstation initialization by taking the following steps:
  3. Start Database initialization> Select Workstation
  4. Fill out the appropriate fields under General and Database
  5. This should bring you back to the Database Initialization screen if it resolves all the fields properly
  6. Launch Continuum and now the error should be resolved
  • 5961
