LOYTEC NIC-USB in NL220
  • LOYTEC NIC-USB in NL220
  • Cody_Failinger
    Cody_Failinger
  • Anonymous user
‎2018-09-07 04:11 AM
  • LOYTEC NIC-USB card shows offline in NL220
  • Cannot communicate to NIC-USB card when opening NL220
TAC Vista
  • NL220
  • NIC-USB
  • Loytec
Proper setup of a NIC-USB in NL220 is required in order for the NIC-USB card to be able to communicate with NL220 or TAC Vista Server.
A tool called LConfig need to be installed on the computer before the configuration. Click here to download and install  the configuration tool (NIC - LOYTEC Network Interface Software 4.1.4).
  1. Connect the NIC-USB to the computer
  2. Use LConfig (Start/All Programs/LOYTEC Network Interface/Lconfig) to configure the NIC-USB
    1. Choose the USB tab
    2. Check "Enable USB Network Interfaces"
    3. Click "Test Device/Serial Number"
  3. Go to NL220. In the project open window, select the correct NIC-USB in the "Network interface" box.
  4. Click "OK"
  • 4221
