Individuals added via Datacard ID Works are not getting access to doors
  • Individuals added via Datacard ID Works are not getting access to doors
  • Cody_Failinger
    Cody_Failinger
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 01:18 PM
TAC INET
  • I/NET
  • ID Works
I/NET uses audit trail messaging to ensure that ID Works data is broadcast out to the site.
  1. Open AMT
  2. Select Edit>Configuration
  3. Note the Group 1 Masking Settings
  4. Open I/NET
  5. Select Access>Options
  6. Select Group 1 for Audit Trail Messaging
  7. Ensure that the masking for Audit Trail is set the same as the AMT Configuration
  8. Select Edit>Host Computer>Network Configuration
  9. Choose the Link that is connected to the Video Badging PC
  10. Verify the Host Number
  11. Set up Automatic DPU Restore Function.
  12. 's means of communication, then make sure that the Host Masking is set to match the AMT Masking for Group 1
  13. If you are still having issues make sure you are using the correct ID Works Template
  14. The Templates are available on the I/NET CD in the Support Folder
  15. If you are using your own template ensure you have these required fields:
  • IndividualId
  • TenantName
  • GroupName
  • RecType
  • TempStart
  • TempStop
  • TempStartDate
  • TempStartTime
  • TempStopDate
  • TempStopTime
  • IssueLevel
  • TAC INET
Tags (3)
  • 6265
  • Datacard
  • ID Works
