How to view the current firmware version on a Xenta controller using the RS-232 cable
  • How to view the current firmware version on a Xenta controller using the RS-232 cable
  • CraigEl
    CraigEl
  • Sacco
    Sacco
  • SESA128463
    SESA128463
‎2018-09-10 05:53 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 10:44 PM
View the current firmware version on a Xenta controller using the RS-232 cable
TAC Vista
  • Vista 5.1.X
  • Xenta Programmable Controllers
  • Xenta 280, 281, 282, 283, 300, 301, 302, 401, 401:B, 901
While it is the best practice to match all of the firmware versions in your controllers, this is a quick and easy way to view the current version installed on your hardware.
  1. Connect the RS-232 programming cable to your controller and your PC
  2. Open TAC Tools 5.1.X
  3. Open Download Wizard
  4. Click next
  5. Click the information button located directly above the help button
For more information on how to update the firmware (.MOT file) on a Xenta controller, see Download an .MOT file into a Xenta Programmable controller.
For more information on Menta Cable needed to download, see Schematic for the RS-232 cable used to direct download Menta applications and system files.
  • 7019
