How to set the neuron ID of an I/O Module in a Vista classic network.
  • How to set the neuron ID of an I/O Module in a Vista classic network.
  • PeterLarsen
    PeterLarsen
‎2018-09-06 02:23 PM
Last Updated: Spock PeterLarsen Spock ‎2022-08-21 04:00 PM
TAC Vista
  • Vista Classic Network
  • Xenta I/O modules
Xenta I/O modules beneath a base unit (300 or 400 series) do not show up in the Folder view tree structure.  You cannot right-click and set a neuron ID the same way you do for a base unit.
  1. Click on the Xenta base unit (300 or 400 series controller) in the tree structure.
  2. This brings up a list of modules inside the Menta file as well as two option modules that cannot be seen from the tree structure-- $IO and $LOGS.
  3. Double click the $IO module.
  4. All of the I/O modules defined in the Menta file are listed here.  Right-click, properties, to set the neuron ID.
Tags (2)
  • 4103
  • PeterLarsen22
100% helpful (1/1)
