Running the Import/Export Fixup Utility
  • Running the Import/Export Fixup Utility
  • Dave_Shore
    Dave_Shore
  • DavidChild
    DavidChild
  • BillNeville
    BillNeville
‎2018-09-06 01:17 PM
Last Updated: Sisko DavidChild Sisko ‎2020-03-09 06:56 AM
How to run the Import/Export Fixup Utility
Andover Continuum
  • CyberStation
  • Import Export Fixup Utility, I/E Fixup, IEFixup, IE,ImpExpFixupUtil.exe
  • CX Controller, i2 Controller, Infinet Controller
Points not updating or alarms not coming in have resulted in PSS asking for the import export fixup utility to be run.
Note: Before performing the steps listed below, make sure a database backup has been performed.
  1. Navigate to the \Continuum directory. The Import Export Fixup Utility is located here
  2. The filename is ImpExpFixupUtil.exe. Double-click it.
  3. It runs in a DOS window and when complete, creates a file in the format IEFixuptimestamp.log. In some cases the log file will open; in others it will be saved to the \Continuum directory.
Tags (2)
  • 6190
  • DavidShore20
