How to locate a computer's MAC address
  • How to locate a computer's MAC address
  • Cody_Failinger
    Cody_Failinger
‎2018-09-06 12:22 PM
How to find the MAC address / Physical Address of a computer.
Andover Continuum, EcoStruxure Building Operation, Other, Satchwell MicroNet, Satchwell Sigma, TAC IA Series, TAC INET, TAC Vista
All computers
The MAC address of a computer may be required when working on licensing issues. MAC stands for Media Access Control and is a unique identifier assigned to network interfaces for communications on the physical network segment.
  1. Go to the Start > Run.
  2. Type "cmd" into the Open field.
  3. In the CMD window, type the command "ipconfig /all".
  4. Locate the connection that the computer is currently using (For this example it is the Ethernet adapter Local Area Connection). You will find the Physical Address (MAC address).
Labels (7)
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
  • 8011
