How to cold start an NPR 2000
  • How to cold start an NPR 2000
  • sesa139513
    sesa139513
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 03:20 PM
How do I cold start an NPR 2000?
Netplus Router - Model NPR-2000-C
Cold starting an NPR 2000 is a common troubleshooting technique to clear up a number of communication problems that may arise.
  1. Open the front cover.
  2. Depress the Idisk holder (looks like a battery holder) so that the conductors short against each other.
  3. While holding that, press the small black button on the front left of the unit. 2 LEDs on the right will begin flashing and continue for about 20-30 seconds (more or less).
  4. When they stop and 2 LEDs to the right and left of them come on solid, press the black button again.
  5. If you did it right, the 4 LEDs will begin flashing back and forth.
  6. The NPR is now in boot state and requires a software restore via the serial port. You won’t be able to connect to the NPR via Ethernet since it is at boot and has no TCP/IP address.
  • TAC INET
  • 1383
