How to change the name of a 527 Link or DLA site
  • How to change the name of a 527 Link or DLA site
  • Derrick_Ratliff
    Derrick_Ratliff
  • CraigEl
    CraigEl
‎2018-09-10 04:02 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:13 AM
TAC INET
  • I/NET Seven
  • XBuilder
  • Xenta 527
In some versions of I/NET changing the name of a Link name through the I/NET Configuration tool will not work on a Xenta 527.
Also, You cannot configure the Name of Link through XBuilder, this must be done as show below.
Before you begin, follow the instructions in How to change the name of a NetPlus Router (NPR) in I/NET. If this fails, or you are performing an initial configuration via XBuilder, use the process below.
  1. Connect to the Xenta 527 via a web browser
  2. Expand the Configuration folder
  3. Expand the Network folder
  4. Click on TCP/IP
  5. Change the Host Name to the desired link name.
  • TAC INET
Tags (2)
  • 6382
  • Change the name of a Xenta 527
