Having set Link Addressing in a Sigma DNN3 can no longer communicate to the DNN3 and Link Addressing does not work.
  • Having set Link Addressing in a Sigma DNN3 can no longer communicate to the DNN3 and Link Addressing does not work.
  • CraigEl
    CraigEl
‎2018-09-06 02:19 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 06:57 PM
After configuring Link Addressing on a Sigma DNN3, communication with the DNN3 fails, and Link Addressing does not function as expected.
Satchwell BAS & Sigma
  • Multiple Sigma controllers across at least two Ethernet VLANs
  • DNN3 devices (version 1.h) connected to each VLAN
  • Port 1 of each DNN3 connects to the VLAN
  • Port 2 is configured as a virtual Serial PPP port (not physically connected to a device)
Although Link Addressing may be correctly configured, the DNN3 devices lack routing information (i.e., static routes).
Without this, the DNN3 cannot transmit point-to-point global data to the appropriate router or default gateway.
Additionally:
  • With both ports configured, RIP (Routing Information Protocol) is enabled by default.
  • RIP broadcasts misleading routing information, advertising port 2 as a valid route, which is incorrect.
  • RIP must be disabled to prevent this false advertisement.
To restore communication and proper Link Addressing functionality:
  1. Add a default static route to each DNN3 using Pocket Terminal 32 via the service port:
    SR+ 0.0.0.0/0 192.168.1.253 1
    • 0.0.0.0/0 is the generic destination and mask
    • 192.168.1.253 is the default gateway
    • 1 is the DNN3 port number
  1. Disable RIP on port 1 of the DNN3:
    RIPD 1
Additional Notes
  • Ensure that no devices are physically connected to port 2 if it's configured as a virtual PPP port.
  • This configuration ensures that global data is routed correctly between VLANs and prevents routing conflicts.
  • Satchwell BAS & Sigma
Tags (2)
  • 4258
  • CraigEllis25
