HTTP Error 500.21 Internal Server Error logging into WebClient. or ASP.NET setup custom has stopped working when trying to register .NET 2 using aspnet_regiis.exe
  • HTTP Error 500.21 Internal Server Error logging into WebClient. or ASP.NET setup custom has stopped working when trying to re...
  • Cody_Failinger
    Cody_Failinger
  • AbeMeran
    AbeMeran
‎2018-09-11 03:02 PM
After completing the installation for 2.0 WebClient the first attempt to logon results in HTTP Error 500.21 Internal Server Error logging into WebClient.
Trying to register .NET 2 using aspnet_regiis.exe produces  ASP.NET setup custom has stopped working.
Andover Continuum
WebClient
.NET 4 not registered with IIS
Register .NET 4 with IIS from Command Prompt (NOTE: Run command prompt as administrator)
  • 17369
