Ethernet port is AutoSensing (No Crossover Cable required)
  • Ethernet port is AutoSensing (No Crossover Cable required)
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
‎2018-09-06 03:48 PM
Need to perform autosensing on an ethernet port but do not have a cross over cable.
Andover Continuum, EcoStruxure Building Operation, TAC INET, TAC Vista
  • Ethernet connection to an Automation Server
  • Xenta device
  • ACX
  • BCX
  • Auto-Sensing, Auto Sensing
  • direct connect
  • Auto uplink and trade
  • Universal Cable Recognition
Need to direct connect with a straight through or normal patch cable from a computer or laptop to the AS, Xenta, BCX, ACX
Since 1998, the distinction between uplink and normal ports and manual selector switches on older hubs and switches are obsolete. If one or both of two connected devices has the automatic MDI/MDI-X configuration feature there is no need for crossover cables.
Now you can plug your laptop right into the Ethernet port of the device with just a regular patch cable.
Labels (4)
  • TAC INET
  • 7982
0% helpful (0/1)
