Error: "Ensure that Vista Server is started" when trying to log into TAC Vista Workstation. The server is started.
  • Error: "Ensure that Vista Server is started" when trying to log into TAC Vista Workstation. The server is started.
‎2018-09-07 01:31 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:41 AM
Error states: "Ensure that Vista Server is started" when trying to log into TAC Vista Workstation. The server is started.
TAC Vista
  • TAC Vista Workstation 4.2.5, 4.3.0-4.5.0, 5.0.0 and higher
  • Microsoft Windows XP Service Pack 2
Microsoft Windows XP Service Pack 2 has security changes/upgrades from previous service packs.  This affects the DCOM permissions that Vista Server relies on. a variety of other reason could result in an error in DCOM parameters in later operating systems.
Vista 4.2.5
  • Apply settings described in this TPI to get TAC Vista to work properly.
Vista 4.3.0-4.5.0
Vista 5.0.0 and higher
  • Apply settings described in TAC Software Installation Manual available on The Exchange Download Center.
  • This can be done using the DCOM Utility in Helpful Vista Utilities - Configure DCOM instantly, Register ASP.NET.
  • Error Message: Ensure that Vista Server is started lists manual steps to access DCOM.
  • 1853
