Datacard ID Works Software versions for integrating with I/NET Seven
  • Datacard ID Works Software versions for integrating with I/NET Seven
  • Tom_Poovey
    Tom_Poovey
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 01:40 PM
What version of Datacard ID Works Software integrates correctly with I/NET Seven?
  • I/NET Seven
  • Datacard ID Works
Usually the customer wants to integrate the Access Control of I/NET Seven with Video Badging software. He is faced with what version is the correct one for this purpose.
The ID Works Standard Version is the product you should choose for this integration. However, there are two different options in this Standard version:
  1. The “Full” Version - ID Works 6.5 with the designer option included
    With this version, badge templates can be modified and badges can be printed. This version will integrate into an I/NET Seven system. (Please Note that you cannot order Datacard thru Iportal anymore) You have to order thru Datacard.
  2. The “Production” Version - ID Works without the designer option
    This version will not allow you to change any of the badge templates. It only allows for printing of badges. This version will integrate into an I/NET Seven system. (Please Note that you cannot order Datacard thru Iportal anymore) You have to order thru Datacard.
  • TAC INET
Tags (3)
  • 5458
  • Datacard
  • ID Works
