CyberStation SQL collation
  • CyberStation SQL collation
  • RobertAndriolo
    RobertAndriolo
  • Clifton_eakes
    Clifton_eakes
  • ScottLeedberg
    ScottLeedberg
‎2018-09-06 02:03 PM
Last Updated: Picard RobertAndriolo Picard ‎2022-03-11 02:26 PM
What SQL collation is supported by CyberStation
Andover Continuum
  • CyberStation
  • SQL Server
Which SQL collations are supported by CyberStation.
Only the SQL_1xCompat_CP850_CI_AS collation has been tested with CyberStation.
Note:
In more recent versions of SQL server (i.e 2005), you can have the Collation on a per-database basis so ContinuumDB will have its collation set to SQL_1xCompat_CP850_CI_AS and another database can use a different collation setting. Also when the continuum database is restored it will retain the original collation that it was created with.
Tags (3)
  • 4730
  • CliftonEakes22
  • RobertAndriolo22
