Creating LNS database in NL220 and transferring it into TAC Vista procedures outline
  • Creating LNS database in NL220 and transferring it into TAC Vista procedures outline
  • Cody_Failinger
    Cody_Failinger
  • Anonymous user
‎2018-09-06 02:20 PM
How to create a LNS database in NL220 and then bring it to Vista Workstation online
TAC Vista
NL220
In order to have a healthy LNS database, it is very important to create this database with proper steps in NL220.
  • Preparation:
    • Configure the Infrastructure Device
    • Set up Vista Database path
  • Creating LNS Db in NL220
    • NL220: Add infrastructure device, nodes, etc.
    • System plug-in: Assign Neuron ID (Optional), Menta file
    • Back to NL220: SNVT binding
  • Bring LNS Db to Vista Db
    • System plug-in: Network settings, Update TAC Network, create group bindings, add I/O modules, update the TAC Network again, check TAC Network, Update Vista Database
  • Bring Vista Db online
    • NL220: Commission the Infrastructure Device
    • System plug-in: Verify network settings, assign Neuron ID if needed, update TAC network and Vista database, download application and parameters
    • Back to NL220: Commission and downloading all nodes besides I/O modules.
    • Back to system plug-in: Change infrastructure setting, commence communication
  • 4220
