Cannot change directory to Continuum error during installation of Cyberstation.
  • Cannot change directory to Continuum error during installation of Cyberstation.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:05 AM
An error stating "Cannot change directory to Continuum" is thrown when trying to install Cyberstation.
  • Installation
  • Cyberstation
  • WebServer
This error usually occurs when the install executable is run from inside the compressed (Zip) file folder.
Copy the contents of the compressed folder (zip file) onto the PC, then launch the setup application.
  • 14350
