Compatibility of Niagara R2 JAR Files Between Different Versions
  • Compatibility of Niagara R2 JAR Files Between Different Versions
  • CraigEl
    CraigEl
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 12:31 PM
Last Updated: Administrator CraigEl Administrator ‎2025-12-09 08:14 PM
Can JAR files from Niagara R2 version 532 be used with a UNC running version 330?
TAC IA Series
Niagara (all versions)
Attempting to fix a known issue by upgrading to a newer JAR file while maintaining the currently installed Niagara version.
JAR files must match the installed Niagara build version.
  • If the UNC is running version 330, only JAR files ending in 3xx should be used.
  • If the UNC is running version 532, only JAR files ending in 5xx should be used.
Mixing JAR files from different Niagara builds is not recommended and may cause instability or integration issues.
  • TAC IA Series
Tags (2)
  • 7614
  • CraigEllis25
