Adding fonts to EpiBuilder or EpiDesigner
  • Adding fonts to EpiBuilder or EpiDesigner
  • Alan_Wood
    Alan_Wood
‎2018-09-06 09:33 AM
Can other fonts be added to EpiDesigner EpiBuilder?
Andover Continuum
  • EpiBuilder
  • EpiDesigner
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
The method to add fonts to EpiDesigner is needed to use alternate fonts.
  1. Download or install the font that is needed to a folder on Windows
  2. Unzip if necessary and then drag and drop the font file(s) into the windows fonts folder and they should automatically install.
    Here are some Windows instructions for installing manually. https://support.microsoft.com/en-in/help/314960/how-to-install-or-remove-a-font-in-windows
  3. After installing the fonts you can open a layout in EpiDesigner and select the newly added font.
  • 16631
