TC303 or TC903 Thermostat set point change with power failure
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • TC303 or TC903 Thermostat set point change with power failure
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
JayangaDivya
Lieutenant JG JayangaDivya Lieutenant JG
Lieutenant JG
Posted: ‎2022-09-06 09:27 PM
1718
Suppose a Thermostat (TC303 or TC903) is running in normal condition then a power reset is occurred. After the power reset, the Temperature setpoint is going to a preset value. It is needed to keep the last Temperature setpoint before the power failure & let us update how this setting can be adjust.
  • Set point
  • tc303
  • TC903
  • thermostat
CraigEl
Posted: ‎2022-09-07 06:44 PM
For the TC300 the setpoint will always return to the default, this is how the device was designed and cannot be changed in the field. For the TC900 I'm not so familiar with but I suspect it is will have the same behaviour.
I know the factory will do modifications (for a price) if the number of devices ordered are large enough and retaining the setpoint through power cycling has been done for at least one job that I'm aware of. You would need to work with your local product management team to find out if this is possible based on the required quantity of devices.
CraigEl
