SpaceLogic Sensors EP Series Rotary Switch
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SpaceLogic Sensors EP Series Rotary Switch
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
enzodino
Lt. Commander enzodino Lt. Commander
Lt. Commander
Posted: ‎2025-02-12 05:14 AM
974
a customer made us a simple question about the rotary switch in the EP Series sensors
the ranges are repeated, as highlighted in yellow, position 0 and position 4 are identical.
In general all settings from 4 to 7 are identical with 0 to 3.
What is means? Set to 0 or 4 is exactly the same in configuration??
Thank you
Best Regards
  • Pressure Sensors
CraigEl
Posted: ‎2025-02-12 03:55 PM . Last Modified: ‎2025-02-12 03:57 PM
@enzodino it looks to me that ranges 1 (0-250Pa) & 2 (250- 2500Pa) there are only 4 possible ranges, so positions 1-4 and 5-8 have duplicated functionality. For range 5 (0-2500 Pa) there are 8 possible ranges, so each position is unique.
enzodino
Lt. Commander
Posted: ‎2025-02-13 02:47 AM
@CraigEl thank you for the answer!
Enzo
milenabare
Crewman milenabare Crewman
Crewman
Posted: ‎2025-02-13 11:39 AM
yes, positions 0-3 are identical to positions 4-7. Rotary position 0 and rotary position 4 would result in the same selected range. This is true for EP models 301 and 302. The only model where the rotary positions are all different from 0-7 is the universal model 305.
CraigEl
enzodino
Lt. Commander
Enzo
milenabare
Crewman
