Panel server connection
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Panel server connection
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
Abhijithnair
Abhijithnair
Cadet
Posted: ‎2025-02-13 02:10 AM
669
When we configure a panel server(PAS600L) under AS-P, Does the panel server work independently when the AS-P is offline?
  • Others & accessories
MikaelKrantz
Guinan
Posted: ‎2025-02-13 04:21 AM
PAS600L is a gateway.
So, what do you think of when you say the AS-P are offline?
If it the connection between the AS-P and PAS600L that is broken, then it can not send anything to or from the AS-P.
If it is the connection between the AS-P and the ES that is broken, then the communication between the AS-P and PAS600L still works.
MikaelKrantz
Guinan
