SpaceLogic PM, CO2, VOC, RH, Temp, Touch, BAC/MB
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SpaceLogic PM, CO2, VOC, RH, Temp, Touch, BAC/MB
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
nigel_greenwave
Admiral | EcoXpert Master nigel_greenwave Admiral | EcoXpert Master
Posted: ‎2025-03-28 04:34 AM
768
Hi, I have just installed 5 x SpaceLogic PM, CO2, VOC, RH, Temp, Touch, BAC/MB - SLPBTCVP2.
The strange thing is 3 out of the 5 don't read any of the PM's. Has anyone come across this before?
Please see below pic.
  • Temperature Humidity & Air quality Sensors
SantiagoFraile
Ensign SantiagoFraile Ensign
Ensign
Posted: ‎2025-04-10 07:28 AM
705
Hi Nigel, How are you? It seems there might be a disconnect between the daughter board and the main board. Please gently press the daughter board towards the main PCBA. When you close the cover, observe the green LED light on the sensor side. It should stay steady for approximately 10 seconds and then flash once. This sequence indicates that the daughter board is properly connected to the PCBA. However, if the LED light remains steady for 10 seconds and then flashes four times, it means the daughter board is still disconnected.
SantiagoFraile
Ensign
706
nigel_greenwave
Posted: ‎2025-04-10 11:05 PM
In response to SantiagoFraile
Hi Santiago,
Yes, this is 100% the issue.
It's strange, it's like the two boards are not connected, like it's just floating. There is no clear connection between the two that I can see. I have sent them all back to Schneider for RMA.
I have a feeling that this is a design issue....
