Gear stripping ag13a020
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Gear stripping ag13a020
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
sheppsr
sheppsr
Cadet
Posted: ‎2025-02-28 06:11 AM
703
We've have been struggling with a single 3way valve actuator at our facility stripping a tooth. It seemed to be a bad batch of actuators but the new shipment we received is doing the same thing. I thought I found the culprit (the metal plate the drive motor mounts to was rotated clockwise decreasing the amount of mesh between the gears) 2 days ago, but it failed again. We've resorted to gluing a piece of cork gasket material to limit the travel of the arm in the closed position. This is on a 2 pipe FCU currently running heat. Boiler temp is currently in the 160F range. The 3way valve stem itself moves freely. Is there anything else we should look into before resorting to replacing the whole valve assembly?
Aaftab
Ensign Aaftab Ensign
Ensign
Posted: ‎2025-04-22 03:21 PM
As the zone valve ages, an indentation forms on the pedal gasket. This causes the actuator to rotate beyond its intended capacity for a tight close-off, eventually leading to actuator failure. To resolve this issue, I recommend replacing the valve or the whole assembly.
Aaftab
Ensign
