Schneider PICV and Danfoss PICV
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Schneider PICV and Danfoss PICV
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Supertech
Hybrid DCS Template Library for Automated On-Off Valves
Back to Intelligent Devices Forum
AhmedAzzam2200
Crewman AhmedAzzam2200 Crewman
Crewman
Posted: ‎2024-10-27 03:43 AM
859
Dears,
I would like to ask if anyone can confirm that the AB-QM 4.0 / AB-QM PICV is same range of our PICVs from DN 10 to 32 and its applicable to use it with SP90 or not?
  • Pressure Independent Valves and Actuators
Simon_Firth
Lieutenant JG Simon_Firth Lieutenant JG
Lieutenant JG
Posted: ‎2024-10-28 07:03 AM
Hi, The Danfoss ABQM 4.0 is a different range of valves to the Schneider Electric PIBCV offer.
The SP90 has a drop down list of valves, this list will only include the Schneider Electric offer.
You can use the SP90 on the Danfoss ABQM 4.0 but but you would need to select custom valve type, define the stroke (4.0mm) , and then the Valve Qmax. for what ever the flow is for the valve it is connected to.
Mr Valve
Simon_Firth
Lieutenant JG
Mr Valve
AhmedAzzam2200
Crewman
Posted: ‎2024-11-04 09:51 PM
Hello Simon,
Thanks a lot for your reply, i just wanted to confirm what i understand, as of now we can request the SP90 for the Danfos Valves, but it will be customized so i need to clarify this when I ordered to the Offer manger.
is it right?
Ahmed Azzam
