SHO2 wrong wiring diagram
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • SHO2 wrong wiring diagram
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
nigel_greenwave
Admiral | EcoXpert Master nigel_greenwave Admiral | EcoXpert Master
Posted: ‎2025-04-08 10:37 PM
2017
We recently installed the new SHO2 RH H type (10K T3 thermistor) outdoor temperature and humidity sensor. We noticed that the wiring instructions are slightly incorrect; Terminal 4 needs a common connection. Please see the attached picture for reference.
Additionally, it’s difficult to understand the terminal numbers on the sensor, and the dip switches are so small that they are hard to see and switch, especially when standing on a ladder.
  • Temperature Humidity & Air quality Sensors
jacqueline_sayegh
Ensign jacqueline_sayegh Ensign
Ensign
Posted: ‎2025-04-23 07:13 AM
1938
The diagram is correct, the voltage outputs should be referenced to pin 2 and not 4.
Jacqueline Sayegh
Exchange Community Manager for HVAC Sensors
Replies 10
jacqueline_sayegh
Ensign
1939
Jacqueline Sayegh
nigel_greenwave
Posted: ‎2025-04-24 01:13 AM . Last Modified: ‎2025-04-24 01:48 AM
In response to jacqueline_sayegh
1921
I can confirm that the wiring diagram is not correct.
The diagram that's within the sensor's enclosure is correct, but the diagram on the paperwork is not
Pic of the diagram on the sensor. which is different to the paperwork
Girish
Girish Cadet
Cadet
Posted: ‎2025-04-25 12:02 PM
In response to nigel_greenwave
Can you confirm the full model number you are referring to. The SHO2 has models with temperature transmitter or passive RTD/ thermistor option. In the install there are two diagrams for wiring one for thermistor and one for transmitter. The one shown on the product refers to the RTD or Thermistor output.
MikaelKrantz
Guinan
Posted: ‎2025-04-27 11:25 PM
1870
As @Girish asked above, more information about the actual device.
A picture of the side of the sensor showing all product info will do.
Have you been in contact with the support about this issue?
nigel_greenwave
Posted: ‎2025-05-05 11:15 PM
In response to MikaelKrantz
Hey Girish,
The model in question is SHO2XA2H Outdoor humidity sensor, 2% RH, 10K T3 thermistor.
To clarify, the paperwork is incorrect. As shown in the picture below, the sensor diagram correctly indicates terminal 4 as Thermistor Out, whereas the paperwork incorrectly shows terminal 4 as open.
My installer couldn't work it out (via the paperwork), and the only answer I had was "it's not correct, use the diagram with the sensor"
MikaelKrantz
Guinan
Posted: ‎2025-05-06 12:47 AM
1833
@nigel_greenwave are you aware that the picture of the paper says Voltage mode, but the red arrow in the picture of t a device does come from the current connections?
Did they use Voltage or Current connections?
nigel_greenwave
Posted: ‎2025-05-06 10:41 AM
Sorry arrow should be from the voltage side because that is what we used.
My question is, why does Terminal 4 have no connection when it should be Thermistor Out?
I'm I missing something here?
MikaelKrantz
Guinan
Posted: ‎2025-05-07 12:12 AM
Can not say for sure for this model, but some of the sensors may have two different thermistors, there you select which one to use by the terminal to use.
One of the datasheet I found does say:
Temp. sensing element** 10K T3 thermistor, 1000 PT RTD
jacqueline_sayegh
Ensign
Posted: ‎2025-05-21 10:50 AM
1689
@Girish please can you comment on the above
Jacqueline Sayegh
Girish
Girish Cadet
Cadet
Posted: ‎2025-05-21 12:46 PM
The install sheet should have two diagrams one for transmitter model like SHO2XA2A and other for thermistor or RTD model like SHO2XA2H/SHO2XA2C.
For SHO2XA2H please refer to the second diagram.
