Looking for MS51-7203 actuator alternative replacement (Service installed based)
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Looking for MS51-7203 actuator alternative replacement (Service installed based)
CraigEl
Administrator CraigEl Administrator
42
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
Wyman_Yeung
Ensign Wyman_Yeung Ensign
Ensign
Posted: ‎2024-09-26 02:36 AM
779
I have a question about any alternative replacement for MS51-7203 actuator?
Valve actuator: MS51-7203 (979 Newton)
Existing Valve body: VB-7225 series
Looking for actuator alternative, any Linkage require?
  • Traditional Valves and Actuators
Simon_Firth
Lieutenant JG Simon_Firth Lieutenant JG
Lieutenant JG
Posted: ‎2024-10-03 07:58 AM
The MS51-5203 is a Spring Return Actuator.
You should be able to use the M900A-VB on this valve, without linkage,
M900AE-VB or M900AR-VB depending on if we are Normally closed or Open
Mr Valve
Aaftab
Ensign Aaftab Ensign
Ensign
Posted: ‎2024-10-07 07:59 PM
MS51-7203 is only spring return up so please use M900AR-VB. If you can share the valve part number, we might be able to provide more options if available. Thanks
Simon_Firth
Lieutenant JG
Mr Valve
Aaftab
Ensign
