Étalonnage du capteur de CO2 SLPSXC2
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Étalonnage du capteur de CO2 SLPSXC2
CraigEl
Administrator CraigEl Administrator
42
Troy_Wecker
Lieutenant JG Troy_Wecker Lieutenant JG
11
Gary
Gary Schneider Alumni (Retired)
11
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Back to Intelligent Devices Forum
ASSSIG-Maroc
Lieutenant JG ASSSIG-Maroc
Lieutenant JG
Posted: ‎2024-09-18 02:49 PM
666
Nous avons installé des capteurs de CO2 SLPSXC2 sur un projet
Suite à la calibration de ceux ci les valeurs remontées de certains capteurs sont incohérentes
Par exemple ceratains capteurs restent à 0 ppm, un autre à une valeur très élevée de plus de 3000 ppm
Est ce que quelqu'un aurait déjà de l'expérience avec ce type de capteur
SantiagoFraile
Ensign SantiagoFraile Ensign
Ensign
Posted: ‎2024-10-03 08:41 AM
After applying the manual or automatic CO2 calibration process, the CO2 values must stay within range. Seeing steady output of 0 ppm or very high values, such as 3000 ppm, shouldn't happen. If possible, please run the calibration process again, and if issue remains, please contact support team.
Manual calibration: Push and hold the calibration button for 3 to 5 seconds. The LED will flash green. Once the button is released, calibration is complete and the LED switches off.
Automatic calibration: The ABC algorithm constantly keeps track of the sensor’s lowest reading over a preconfigured time interval and slowly corrects for any long-term drift detected as compared to the expected fresh air value of 400 ppm. After initial startup, it is expected that the sensor reaches specified accuracy after 7 to 21 days.
SantiagoFraile
Ensign
