IP Class of SP90 actuator
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • IP Class of SP90 actuator
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
FlatBeach
Sisko FlatBeach Sisko
Sisko
Posted: ‎2024-07-11 12:16 AM
684
I don't get it....
Can anyone tell me why the first number in the IP class changes on the SP90 valve when it mounted with the actuator down? It goes from 5 to 4 which mean it goes from being protected from dust to protected against objects with a diameter greater than 1mm.
  • Communicating Actuators and Energy Valves
CraigEl
Posted: ‎2024-07-11 12:24 AM
@FlatBeach just a guess, gravity... the moving parts for the plunger are all on the underside and in the upside-down position they become more exposed. It's unlikely that anything would fall upwards and lodge in there when mounted normally.
CraigEl
