Discover SpaceLogic Duct and Plant Room Air Quality Sensors
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
  • EcoStruxure Building
  • Intelligent Devices
  • Discover SpaceLogic Duct and Plant Room Air Quality Sensors
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Kirk MikaelKrantz Kirk
11
Gary
Gary Schneider Alumni (Retired)
11
Back to Intelligent Devices Forum
BT7
Ensign BT7 Ensign
Ensign
Posted: ‎2024-03-15 09:15 AM . Last Modified: ‎2024-03-15 09:45 AM
6
2646
Welcome to the SpaceLogic Duct and Plant Room Air Quality Sensors Page!
Get SpaceLogic Duct and Plant Room Air Quality Sensors Video and discover its cutting edge benefits!
Introducing the SpaceLogic Duct and Plant Room Air Quality Sensors.  The series comprises all-in-one sensors for monitoring air quality.  The multi-sensor combines CO2, Temperature, Humidity, Volatile Organic Compounds (VOC) and Particulate Matter (PM) sensing into a single unit to ensure a building’s optimum air quality and energy efficiency.
The sensor features medium and optimum solutions offering flexibility based on application requirements and budget and data analytics for easy maintenance.
Capabilities of this sensor solution include:
  • Best-in-class sensing
    • Indoor Air Quality : 8-in-1 multi-sensor – Temperature, Humidity, CO2, VOCs and Particulate Matter(1, 2.5, 4, 10)
  • Labor cost savings in installation with screwless terminal block and latch-on cover
  • Diagnostic data to troubleshoot
  • Field replaceable humidity module
  • Simple 3rd part integration
  • Open protocols: Modbus and BACnet
  • LCD backlit display
  • Customizable options
  • Connectivity with the Ready-Connect Plug and Play Experience
You will find below a summary of key SpaceLogic Duct and Plant Room Air Quality Sensor assets.
  • Technical Assets:
    • SCD2 Air Quality Sensors – BACnet & Modbus Installation Instructions
    • SCD2 Air Quality Sensors – Analog Installation Instructions
    • SHD2 Series Humidity Sensors – BACnet & Modbus Specification Sheet
    • SCD2 Series Air Quality Sensors Specification Sheet
    • SHD2 Series Humidity Sensors – BACnet & Modbus Installation Instructions
  • Promotional Assets
    • Promotional Video
    • SpaceLogic Plant Room Sensors Brochure
Barbara Tracey
Field Devices Product Marketing Manager
  • Temperature Humidity & Air quality Sensors
ZeeZee97
Administrator ZeeZee97 Administrator
Posted: ‎2024-08-22 04:02 PM
Thank you Barbara!
Zineb EZ-ZERROUQI
calistamargo
Crewman calistamargo
Crewman
Posted: ‎2024-09-10 04:33 AM
Good One!
BY USBRestore.com
Replies 6
ZeeZee97
Thank you Barbara!
Zineb EZ-ZERROUQI
calistamargo
Crewman
Good One!
BY USBRestore.com
Steve
Admiral | EcoXpert Master Steve Admiral | EcoXpert Master
Posted: ‎2024-09-24 11:26 AM
2305
Where can I find the modbus register map for these devices. Also, that data sheet mentions some sort of Building Application tool. Where can that be found?
Steve Joanis
Chief Technology Officer @ ENE Systems
CraigEl
Posted: ‎2024-09-24 09:26 PM
In response to Steve
1
2289
@Steve the BACnet and Modbus Installation Instruction documents linked in the original post have the register mappings.
I'm not sure I understand what you are referring to with the Building Application Tool, maybe it's the device templates that are posted to the BMS Applications site. Schneider - BMS Applications (schneider-electric.com)
Steve
Posted: ‎2024-09-25 07:14 AM
In response to CraigEl
Thanks. I found MB-263 which had a file to import. I believe that the site you show is what the data sheet was calling the "Building Application tool".
Steve Joanis
RoseCliver
RoseCliver
Cadet
Posted: ‎2024-10-21 03:04 AM . Last Modified: ‎2024-10-22 12:53 PM
  • Technical Assets:
    • Atfbooru
    • Promotional Video
Discover SpaceLogic Duct and Plant Room Air Quality Sensors, an all-in-one solution that monitors Temperature, Humidity, CO2, VOCs, and Particulate Matter. Featuring easy installation, a field-replaceable humidity module, and support for Modbus and BACnet, these sensors offer customizable options and a user-friendly LCD display for optimal air quality and energy efficiency. Explore our installation instructions and specifications for more details!
