Can I increase the maximum number of search results in EBO?
Intelligent Devices Forum
Schneider Electric support forum about all Intelligent Field Devices brands of Sensors, Thermostats, Glass Touch Panels, Valves and Actuators
Showing results forΒ
Did you mean:Β
  • EcoStruxure Building
  • Intelligent Devices
  • Can I increase the maximum number of search results in EBO?
CraigEl
Administrator CraigEl Administrator
42
MikaelKrantz
Guinan MikaelKrantz Guinan
11
Gary
Gary Schneider Alumni (Retired)
11
EcoStruxureβ„’ Building Operation
Back to Intelligent Devices Forum
SchneiderMatt
Crewman SchneiderMatt
Crewman
Posted: β€Ž2024-07-22 07:53 PM
1519
On occasion I want to search for large quantities of objects. Trends for example, on a relatively unknown site, so I simply search for all (relevant) trend objects. If the search returns more than 5000 hits it gives the error message "Your search resulted in too many hits".
Is it possible to increase the maximum number of hits from 5000?
  • Others & accessories
CraigEl
Posted: β€Ž2024-07-23 05:05 PM
@SchneiderMatt  I don't believe so, too wide a search could bog down the server so it's best to limit the search scope by restricting the range of the search
SchneiderMatt
Crewman
Posted: β€Ž2024-07-25 04:19 PM
As I expected Craig, but it was still worth an ask in case someone had a workaround.
Thanks for replying. πŸ™‚
Scott_Depner_BCM
Spock Scott_Depner_BCM
Spock
Posted: β€Ž2024-07-26 11:58 AM
I don't recall what version the limit was removed of 5000, but upgrading to a newer version maybe 3.2 or higher when you uncheck stop at 1000 it won't stop.  I just did one at 5.0.3 that had 50,000 results.  Keep your columns to a minimum and target by object type and name if possible.  50,000 results across an ES and 3 AS's took 5-10 minutes to complete.
Scott Depner, Software Engineering Manager, BCM Controls Corporation, depners@bcmcontrols.com
Replies 4
CraigEl
SchneiderMatt
Crewman
Scott_Depner_BCM
Spock
SchneiderMatt
Crewman
Posted: β€Ž2024-08-08 08:41 PM
Thanks Scott.
Sadly this site remains on 1.9. Fingers crossed for moving up to a current version!
Β
