t300 router ip
  • Industrial Automation
  • t300 router ip
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
PowerLogic T300
MatiasVqueira
MatiasVqueira
Cadet
Posted: ‎2025-02-10 08:11 AM
867
t300 router ip
Hola necesito ayuda para resolver un problema en un Schenider T300. Pude configurar el IP, pude configurar la mascara de red, pero al intentar configurar la puerta de enlace me sale un cartel con el siguiente error: " Se produjo un error en la solicitud SOAP t3''Applyconf. (Error de Ewserver. La nueva configuración fallo. La ultima que funcionaba se restauró correctamente). Gracias
Adjunto Imagenes
Hi, I need help to solve a problem on a Schenider T300. I was able to configure the Subnet IP, I was able to configure the subnet mask, but when trying to configure the @routerip I get a banner with the following error: "An error occurred in the SOAP t3''Applyconf request. (Ewserver error. The new configuration failed. The last one that worked was restored correctly)
I attached images. Thanks.
  • Connected Products
  • Cybersecurity
  • routerip
  • t300
Mathieu_Lansoy
Lt. Commander Mathieu_Lansoy Lt. Commander
Lt. Commander
Posted: ‎2025-02-18 08:42 AM
could you please be more explicit with the IP settings you're trying to enter, and share the firmware version ?
   Mathieu.
