ecostruxure Machine Expert 241 File Transfer issue
Send InviteCancel
Posted: 2025-08-1905:29 AM
Hi All,
I was using the standard solution for file transfer from WebVisu to System. earlier It was working fine. but after installation of Machine expert V2.3 it has stopped working.
can someone suggest if we need to enable any setting in the controller to achieve the same?
