EPO 2022 Client Runtime Issue
Send InviteCancel
Posted: 2025-08-1912:04 AM
I've built a data center BMS system using the EPO 2022 program. The default configuration is server redundancy with four clients. A total of seven IO Servers are currently in operation. The default port number is 2082 for the primary IO Server, and 4080 to 4085 are assigned to IO Servers 2 through 7, respectively. The current issue is that, while the client runtime is running normally, for some reason, some tag values from devices connected to the IO Server on the default port 2082 are being processed as if they are not communicating properly. Some tags from the same IO Server appear normally in the runtime screen. I'm completely baffled by this issue. I've checked the log files, but I haven't found anything unusual. If you have any information on what to check to determine the cause of this issue or a solution, please help.
