Zelio SR3B261BD Serial Communication with HMISTO715
  • Industrial Automation
  • Zelio SR3B261BD Serial Communication with HMISTO715
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
RoozeeR
Lt. Commander RoozeeR Lt. Commander
6
anooprc
anooprc
Cadet
Posted: ‎2025-10-07 06:30 AM
153
I currently have a Zelio SR3B261BD and i need to establish Serial interface RS-232C communication with HMISTO715.I have the Cable SR2CBL09 with me but the problem is HMISTO715 comes with RJ45 Port and SR2CBL09 comes with a 9-pin terminal block.So can i convert this 9-pin terminal block to RJ45 Pin to connect to RJ45 Port.
If so how to do that.
  • Process Automation Talks
Bastian_Schmitz
Admiral
Posted: ‎2025-10-09 06:08 AM
HMISTO705 is in that case the correct one. In your case you need to bild a cable.
 you will find the pictures in the manual
anooprc
anooprc
Cadet
Posted: ‎2025-10-16 07:22 AM
So i would use RJ45 Terminal connector as attached.
TXD,RXD and SG signals will be there except DTR I think it won't be a problem in communication right?
