Operator Terminal Expert : Personal objects
  • Industrial Automation
  • Operator Terminal Expert : Personal objects
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
rfond
Ensign rfond
Ensign
Posted: ‎2025-02-21 06:04 AM
6
1194
Hi everybody,
I would like to do the same as in Vijeo Designer with "placeholders." I want to create graphical objects where I can replace local variables with PLC variables.
Is it possible to do this without using a script?
Or do I have to follow this example:
https://www.se.com/be/fr/faqs/FAQ000258783/
Thanks!
  • Process Automation Talks
  • eote
Replies 6
Bosswaffle
Lt. Commander Bosswaffle
Lt. Commander
Posted: ‎2025-02-22 02:47 PM
This is actually why I haven't switched from Vijeo Designer to OTE. When I tried OTE version 2 something, it had zero support for dynamic variables, and based on the FAQ you linked it doesn't look like the situation is much improved now.
Sorry I can't be helpful.
LeTomas
Lt. Commander
Posted: ‎2025-02-23 11:40 PM
1156
Hi @rfond ,
The placeholder feature is not available on Operator Terminal Expert....yet.
It may be available in EOTEv4
The advice on that FAQ is a workaround for not having the placeholders it will help you to reduce time for sure, if you have already a different structure in plc (if i am not wrong) you can "bind" the variables to the new array.
Best regards,
rfond
Ensign rfond
Ensign
Posted: ‎2025-02-23 11:46 PM
In response to LeTomas
1153
Do you have a release date for EOTE v4 ?
Thank's !
Bastian_Schmitz
Admiral
Posted: ‎2025-06-12 10:58 PM
In response to rfond
Eote 4.0 Will be released In few Weeks
RussellPalmer
RussellPalmer
Cadet
Posted: ‎2025-10-08 11:55 AM
Hi All,
We now have a copy of V4. Do you know if this feature is now included, and if so, where it is or what it is called?
Regards
moominza
moominza
Cadet
Posted: ‎2025-10-16 05:54 AM
I still need 3 functions.
1. can not currently insert trend in compounded object, is there any reason for it to be excluded
2. in compunded object properties why cant i add by user data type as an object. i would like to link 1 item not the 15 items that go with it.
3. why cant i do bit stripping?
