Will This Setup Work? ESP32 to Schneider Electric PLC via Modbus TCP
  • Industrial Automation
  • Will This Setup Work? ESP32 to Schneider Electric PLC via Modbus TCP
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
nf1p
nf1p
Cadet
Posted: ‎2024-12-13 04:06 AM
1146
Hello everyone,
I’m planning to work on a project involving an ESP32, a Schneider Electric PLC, and an HMI panel. The setup involves the following:
  1. ESP32 connected to a sensor, transmitting data using Modbus TCP.
  2. Schneider Electric PLC receiving data from the ESP32 and storing it in internal registers (e.g., %MW).
  3. HMI displaying data read from the PLC registers.
The network would be configured as follows:
  • A local router acts as the communication hub.
  • ESP32 connects via WiFi, while the PLC is connected to the router via Ethernet.
  • All devices, including the HMI, are in the same local subnet.
My Questions:
  1. Does this architecture seem viable?
  2. Are there any specific pitfalls I should watch out for when configuring Modbus TCP on both the ESP32 and the PLC?
  3. Has anyone worked with a similar setup using Schneider Electric equipment and encountered issues I should be aware of?
I want to ensure everything is configured properly before diving into implementation. Any advice or suggestions would be highly appreciated!
Thanks in advance for your help!
  • Smart Design & Engineering
  • Training
Bastian_Schmitz
Admiral
Posted: ‎2024-12-16 01:28 AM
I don´t see any problem in this configuration.
Hennie_Smith
Lieutenant Hennie_Smith Lieutenant
Lieutenant
Posted: ‎2025-01-05 10:22 PM
Hi, I have done a ModbusTCP/RTU gateway with Pi Pico using CircuitPy which I find has good MB support libraries available. Note that the ESP in your case should be ModbusTCP slave with the PLC polling it as the MB Master.
Mael
Mael
Cadet
Posted: ‎2025-03-23 06:04 AM
Hi everybody,
I work on a project for my students. I have a reduced robot controlled by an esp32 , is it possible to make it communicate with an M221 in modbus TCP directly by wiring ? (no hub )
Thx
