[Vijeo Deisgner] Is it possible to replace image on vdz file without software?
  • Industrial Automation
  • [Vijeo Deisgner] Is it possible to replace image on vdz file without software?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Harmony HMI
StevenCho
Lieutenant JG StevenCho
Lieutenant JG
Posted: ‎2025-03-26 09:46 PM
528
Hi there,
I have more than 100 HMIs that has to be used unique image.
So to do that, I have to open .vdz file and modify. Then I will get 100 of .vdz file.
So, to maximize the efficiency, I am looking for the way to replace image on HMI program.
I found there is bitmap image file on the path below.
C:\Users\Public\Documents\Vijeo-Designer Basic 1.2.1\Vijeo-Manager\ImageReplaceTest\Build\Projects\Target1
I tried to change bitmap image but on Vijeo Designer, the image is not changed.
If somebody know any solution like this, please help me🙂
Thank you, In advance.
  • Process Automation Talks
  • Training
ismailozinan
Commander ismailozinan Commander
Commander
Posted: ‎2025-03-30 10:31 AM
I don't recommend trying to access the files via c:public>documants>vijeo, this directory is used by vijeo.
We are recommended to do our operations with the software itself.
StevenCho
Lieutenant JG
Posted: ‎2025-04-02 05:46 PM
Thank you for the answer.
So the only way is edit the image file path on Vijeo software, right?
