Using Different Cable For My ATV12HU22M2
  • Industrial Automation
  • Using Different Cable For My ATV12HU22M2
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Altivar Process (Low Voltage)
ImHeroIC
ImHeroIC
Cadet
Posted: ‎2022-02-16 01:13 AM . Last Modified: ‎2022-02-17 05:43 AM
1192
Hi Guys, My soMove cannot detect my Inverter ATV12HU22M2 , im not using TCSMCNAM3M002P  cable, im using USB to RS485 , does this inverter only support cables recommended by schneider or can use other cables?
Bastian_Schmitz
Admiral
Posted: ‎2022-02-17 05:48 AM
Normally you can use any USB to RS485 adapter. I did some tests with atv320 and it works in all cases successfull. Maybe check your wiring or your selected virtual com port in SOMOVE.
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-02-17 03:14 PM
Are you sure you have a USB to RS485 cable, and not just a USB to RS232 cable?
USB to RS485 aren't all that common.  Generally I end up using a USB to RS232 and then an RS232 to RS485 converter.
