Posted: 2024-03-10 10:33 PM
It's need to check one thing for customer is that TeSys island Function block in Global Library is not working in S7-PLCSIM application.
Is it no way to use Simulator with TeSys island block as other function blocks?
(Error message when Simulation running)
Thank you in advance.
Posted: 2024-03-11 09:59 PM
Do you have the option in your Project for 'Support simulation during block compilation' selected?
I would have expected even Know-How protected blocks could be compiled for Simulation support. But only if you've got it selected in your project.
Posted: 2024-03-14 12:22 AM
Hi Bevan Weiss,
This option setting is disable to check seems like a gray box.
So I think is this unable to use a simulator or not..
Posted: 2024-05-09 08:11 PM
I assume you had the project Offline when you tried to change this?
It's obviously not something that can be changed Online.
