Posted: 2022-11-09 08:28 AM
Good morning All, has anyone ever used a Siemens Comfort HMI with a Schneider TM241 PLC or another Schneider PLC.
Using EcoStruxure Terminal Expert,
Machine Logic Builder Expert,
TIA Portal V17
Having trouble finding this info.
Thanks in advance
Posted: 2022-11-09 08:53 AM
The Siemens Comfort Panels should have a Modbus RTU/TCP driver.
With this is should be easy to connect a TM241.
I would not expect that Siemens offer a codesys/somachine drive for communicaiton via variabellist.
And from the other site Operater Terminal Expert has a TIA driver and also a Modbus Driver. Both should offer a possibility to talk to a Siemens PLC.
best regards
Bastian
