Saving data from SD card to USB using switch function "Copy data to drive"
Send InviteCancel
Posted: 2025-02-0503:01 AM
I trying to copy data which are stored in SD card in HMIG3U to USB. I already tried function "copy data to drive" ´, but when i try to press it i get HMI warning: " The requested file was not found" even tho I have connected USB (HMI confirms that).
