Posted: 2020-03-04 05:30 AM
Hello everyone,
I would like to know if it is possible to use an RS485 connection with the Sub-D9 plug of an STB NMP 2212.
Thanks you in advance.
Best regards
Posted: 2020-03-04 09:43 AM
Hi @Omaelk ,
This product is not part of EBO. It is part of the industrial automation offer.
Mahmoud
Posted: 2020-03-05 12:41 AM
@Anonymous user wrote:Hello everyone,
Best regards
Yes, Modbus Plus is typically RS485.
But I don't think you know what RS485 is.
So I think you're asking the wrong question.
In which case, the answer to your 'actual' question, can the STB NMP 2212 be polled as a ModbusRTU device? is NO! The STB NMP 2212 is a Modbus Plus device, and Modbus Plus is not the same as ModbusRTU
https://en.wikipedia.org/wiki/Modbus
Posted: 2020-03-04 06:19 AM
Hey @Anonymous user , thank you for your question
I moved it to the EBO forum where the community of experts will be able to provide you the right support and solve your issue!
PS: don't hesitate to check the Knowledge base and use the search bar with keywords. there is a lot of content discussed everyday and your issue may have already been solved 😉
Posted: 2020-03-04 06:48 AM
Thanks you for your answer ! I will check the Knowledge base too.
Best regards
Hi @Omaelk ,
Mahmoud
Posted: 2020-03-05 12:24 AM
Best regards
