ST6 Web Viewer and Secure Connect
  • Industrial Automation
  • ST6 Web Viewer and Secure Connect
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Secure Connect Advisor
Harmony HMI
kmelendez
kmelendez Cadet
Cadet
Posted: ‎2024-09-23 10:06 PM
862
Is it necessary to purchase a Secure Connect license to be able to link with an ST6 HMI that is not on the same network or can third-party applications be used? and if I have my Secure Connect license, do I need Web Viewer license?
  • Connected Products
  • Edge Control
  • Smart Operations
Bastian_Schmitz
Admiral
Posted: ‎2024-09-24 01:50 AM
The licences are completly independent.
If you use an other VPN connection to an external network like SCA it will also be possible to use the Webviewer. The advantage of SCA + Webviewer is that you have the possibility to connect to the HMI easily via SE Industrial Device App via Smartphone or tablet.
Bastian_Schmitz
Admiral
