SCADAPack 474i read only filesystem
  • Industrial Automation
  • SCADAPack 474i read only filesystem
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
RemoteConnect for the SCADAPack x70
seacunab
seacunab
Cadet
Posted: ‎2024-11-07 12:30 PM
957
Hello
I have a SCADAPack 474i but I can not create any file because the linux filesystem is read only mode.
How to change to read-write mode?
Best regards
  • Edge Control
  • spanish
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2024-11-08 08:29 PM
I suspect that the SCADAPack design imposes this read-only aspect.
To get around this, you likely have to redploy your own custom Yocto image based on the Schneider standard image.
https://docs.yoctoproject.org/next/dev-manual/read-only-rootfs.html
I believe there are only certain mount points which are on read-write file systems.
From the docker example https://www.youtube.com/watch?v=GMnwrUbNRxU, it looks like /home/root/... is on a write-able file system.  And it suggests that /etc is also (to allow for resolve.conf to be updated... although it's possible this is just a RAM disk, and is reset on each power cycle).
seacunab
seacunab
Cadet
Posted: ‎2024-11-09 08:08 AM
Hello @BevanWeiss
This issue is affecting create docker container in the home directory
But, based on your suggest, I can create into /etc folder, but is not the ideal. I would like create into /home folder.
For now, I continue with this workaround
Thank you
robertobruttomesso
robertobruttomesso
Cadet
Posted: ‎2025-02-28 03:10 AM
Hi, if you check the following document
"SCADAPack 47xi Application Note - Docker App Connectivity and Redis Overview"
at page 14 you can read:
"The SCADAPack 47xi filesystem image is read-only but can accept a read/write filesystem overlay
that resides on the Edge platform’s SD Card. Installing the overlay causes the read-only filesystem to
become read-write. To make any changes to files on your Edge platform, you need to have a
filesystem overlay installed."
hope that helps
