Request 244LD with Remote Transmitter for (HP) High Pressure Steam drum application/Ambient Temp 100 DegC
  • Industrial Automation
  • Request 244LD with Remote Transmitter for (HP) High Pressure Steam drum application/Ambient Temp 100 DegC
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Posted: ‎2020-04-29 11:04 AM . Last Modified: ‎2021-06-03 07:51 AM
3
3627
Now we are proposed 244LD LevelStar model: 244LD-SS3R2RNNH1C4-ML124 for High Pressure Steam drum application to replace the existing Level Switch old design.
Process condition is very hot environment as below;
-Pressure  = 94.8 kscg
-Temperature  = 306 C
-Ambient temp is 100 DegC
Right now customer concern about ambient temp is 100DegC will be make our  244LD transmitter to failure in short time.
Now they are request 244LD with remote mounting and please support this request.
Note: 244LD with Remote Transmitter “Checklist for Level-ECEP” has been submitter to email: tco.level@se.com
  • Level and Pressure Instrumentation
  • Liquid level
Jeff_Blair
Jeff_Blair Schneider Alumni (Retired)
Posted: ‎2020-04-29 12:16 PM
2
3622
Thanks for the question/request!
ECEP request will have to go in to tco.level@se.com as the remote is not a standard offering anymore.
You may also consider IMV31 as an alternative or backup technology.
We've used those successfully on several boiler level applications before.
Jeff_Blair
2
3623
Posted: ‎2020-04-30 01:52 AM
In response to Jeff_Blair
3619
Customer is preferred to go with Level Displacer Transmitter because they have another steam drum also used displacer type.
And I heard about IMV31 going to discontinue product in Dec 2020.
Jeff_Blair
Posted: ‎2020-07-24 06:27 AM
In response to Anonymous user
As this is a public forum I can't comment on any product lifecycles, roadmaps, etc.
Please take a look at the IMV31 and/or work with the TCO team for an ECEP request.
The Exchange is *not* a substitute for our TAC (fielddevices-support@se.com) or TCO (tcoi.level@se.com) teams.  They are our official technical experts.
